Codes and Lights after E-Fan install
04 Sierra w/a 5.3 Here's my Story:
Sunday: put LS1 fans on my truck with a Black Bear Harness... no problems Monday: Intermitent flashing Battery Not charging, go to check it inthe evening, the light won't come on and everything is fine. Drive it home and it's back to flashing Battery Not Charging. Tuesday: Take it to my parents to check why it's not charging, move the truck around in the driveway and the light stops flasing and it's charging fine. Then it throws code P0443 Wednesday: Back to Flashing Battery Not Charging and and still has the code P0443 I NEED HELP BEFORE I BURN THIS F**KING TRUCK TO THE GROUND!!!!!! Can you tell it's pissing me off? Thanks! |
That code is for evap canister i beleive no relation to the e-fan install. Did you use pin 43 and what is it 34 i think? Or did you tap the a/c wire directly? You could have fucked up another wire in the harness or maybe your battery ground is loose?
Originally Posted by Toaders
(Post 4246445)
What should I look for on the evap side? |
Ok... I THINK that I've solved my problem. Looks like when i put pin 33 in the red (green on my truck) pmc connector I didn't get to lock in and it pushed most of the way back out. Got that Locked in like it should be and so far, no issues.
