code P0717 and..
Old Oct 28, 2009 | 06:56 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default code P0717 and..
truck runs fine. but its throwing the P0717 (input turbine speed sensor no signal)... lets say in in R or D.... and i try to foot brake it, it just wont do it, not even a chirp. it will act as if it has a 2 step on it spits and sputters, but one i let my foot off the brake it will burn em down
does this weirdness have anything to do with this sensor malfunctioning?... i had my pump replaced and it doesnt have the sensor in it
Old Oct 28, 2009 | 07:29 PM
00Silv4.8's Avatar
make sure its plugged in since the replacement? I know its a dumb thought but it happens...
Old Oct 28, 2009 | 08:08 PM
Daryn's Avatar
the 4l65 pump that was put in doesnt have the sensor in it. im goin to have to find a newer 70E pump and swap them out
Old Oct 28, 2009 | 09:31 PM
budhayes3's Avatar
PT's Slowest Truck
I'm going to guess that the sensor not being there is causing the spitting and sputtering...
Old Oct 28, 2009 | 09:45 PM
Daryn's Avatar
yes thats the cause!
Old Oct 29, 2009 | 01:36 PM
Daryn's Avatar
hmm, i dont remember my other converter makin it do this, do yall think it could be my converter?
Old Oct 29, 2009 | 01:48 PM
Daryn's Avatar
is there anyway we can tune this stupid sensor out?
Old Mar 13, 2021 | 06:39 PM
Drspencer's Avatar
5 Year Member
Didn’t want to start a new thread.
2008 avalanche. GM factory remanufactured transmission with warranty. 0 miles. Getting 0 RPM in the ISS. 12volts to the trans. No blown fuses.
before I pull this trans. Anything I’m missing or haven’t done? Truck is now back to stock. Factory trans tune and everything.
Old Mar 13, 2021 | 06:50 PM
madmann26's Avatar
You mean VSS right?
Pull the sensor and see if the tone ring is there. If not, That’s your issue.
Old Mar 13, 2021 | 07:02 PM
Drspencer's Avatar
5 Year Member
No, I mean ISS. 2007.5 and up SOME came with an internal speed sensor in the pump and a output speed sensor. The trans I took out, the original trans has one. Last test to do is the pin out on the one installed. The one I took out was 4ohm. So at least I know it’s there.
