Class 2 Communications Issue??
Old 05-02-2017, 06:39 PM
Registered User
Robotech's Avatar
Originally Posted by About20ninj45
When i had that issue, it was from the hi/lo data lines having a short/break in the wire
Hi/Lo Data lines?
I actually have an update on this. I checked the voltage across pins 2 (data bus) and 5 (system grounds) in the OBD2. Key On Engine Off (KOEO) and Key off there is 11 volts across the pins. I've read it should be 5. I assume that this means the bus has gotten connected to a constant positive connection somewhere.
I figure my next course of action is to find the Splice block and isolate the individual module connectors and test them to ground to see which one is carrying that 11V current.
Old 05-02-2017, 09:22 PM
About20ninj45's Avatar
With canvas, you have high and low
Idryfly5
09-02-2022 08:55 PM
murderedSS
27
10-12-2015 11:13 AM
TAPyvehc93
09-14-2015 01:22 PM
dselby25
09-11-2015 05:03 AM
Boyes50
09-08-2015 12:06 PM
Quick Reply: Class 2 Communications Issue??
