Cats or O2 sensor
Old Dec 12, 2015 | 04:43 PM
600 horses's Avatar
Default Cats or O2 sensor
My truck is kicking PO420 which also includes PO171 and PO174. I'm trying to diagnose are my cats going out or would it be the o2 sensors and is it causing the lean codes? This may have been posted before but I couldn't find a thread. Any help is appreciated.
Old Dec 12, 2015 | 05:09 PM
FFDP's Avatar
Both are lean code, I'd figure those out first and then see if the cat code is still there after.
Old Dec 12, 2015 | 08:12 PM
600 horses's Avatar
The PO420 code hit first the lean codes just happened. I have cleared the codes and checked what I could for the lean codes. I have even put the original intake tube and air filter housing back on to make sure my CAI didn't have a leak somewhere.
Old Dec 12, 2015 | 08:19 PM
Wolftrk99's Avatar
Check clamp on the throttle body of the cai they are infamous for coming loose especially if they have the rubber hose that rarely actually fits the throttle body with it.... P0171/p0174 are typical for intake gaskets leaking too.... P0420 couldve been caused by lean condition as well not enough variance between front and rear o2 on bank 1
Old Dec 16, 2015 | 05:18 PM
Last Call's Avatar
TOTM: January 2007
Maybe a leak in the intake set up (vacuum lines, map sensor, etc)? Potentially an exhaust leak at the head or header flange?
MileHighSierra
11
Nov 24, 2015 06:17 PM
MJs1FastSS
Feb 17, 2013 02:20 PM
SuthernFlames316
Nov 2, 2007 03:25 PM
duwem
Oct 4, 2005 08:48 PM
LVSTOGOFST2002
Jan 3, 2005 06:06 AM
