Cam tuning tips
Cam tuning tips
I would like some tips for tuning my TR220/112 that should be here next week. I've never tuned for a cam so Im not sure on exactly what I need to change other that idle and fuel trims mabye?
Let's hear what you guys have found to work best with this cam.
Thanks in advance!
Thanks in advance!
Raise idle airflow by 30-50%, add 4-5º to the idle timing tables from 0-800rpm, Match you cranking VE table to the low end o your primary VE table (you'll have to interpolate some of the table) raise idle initially to 750rpm and then lower it from there once it's idling.
FlowmasterMufflers
07-09-2015 11:35 AM
