Cam in. Miss Fire?
Old Jul 2, 2010 | 05:33 AM
slowZ71's Avatar
Default Cam in. Miss Fire?
It crank strait up, idled fine. Light tap of throttle made it rev fast.
After the first break in and cool down, it has been throwing miss fire codes...
When the code is cleared it starts running better (shouldn't matter though.) And 1/4 throttle is about the same as few throttle. We put ARP stud grease on the the plugs pretty thick and was wondering if it wasn't getting good contact with block, or cause a/f and timing is off a little?
Can't get in touch with my tuner. It has fattened itself up so it'll idle, soo it could be getting a little too rich at idle?
5.3l, 220/224, iridium plugs, long tubes, and ory, head work, tune, cai, etc
Old Jul 2, 2010 | 06:06 PM
terravast4's Avatar
maybe the knock sensors need to be adjusted in the tune
Old Jul 2, 2010 | 06:07 PM
GMCtrk's Avatar
The exhaust reversion caused by the cam tricks the pcm into thinking the engine is misfiring. You need to have your tuner alter the tune for it. Basically I had the same problem and solved it by decreasing the misfire sensitivity below 1500 rpms
Old Jul 2, 2010 | 06:15 PM
terravast4's Avatar
were you seeing a misfire at cold start-up?
Old Jul 2, 2010 | 07:53 PM
slowZ71's Avatar
umm... not cold start up. Just like after you have drove it a while. Once it acts up, you cant even crank the thing!
I got a scanner and it shows timing all above 10 deg. 25 full throttle, 3x's cruising, and 30-40 coasting. It has thrown the code about 10 times in one day.
Denali08
Aug 9, 2015 04:34 PM
Jake99
Aug 8, 2015 07:56 AM
steves86ta
Jul 28, 2015 10:21 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
