BCM help
Old Apr 27, 2006 | 12:00 AM
Kingpimp's Avatar
Default BCM help
I was considering uprgrading my 99 bcm to an 02. I want to be able to use the override button to turn off the lights as well as program my locks to open when I put the truck in park. I searched the forums and people had thought about this, but I couldn't find anyone who has done it. Is there any issues I should be aware of before buying the bcm? Has anyone else done this?
Old Apr 27, 2006 | 12:03 AM
smooth_addictions's Avatar
i was curious about the same two things myself. seeing's how i have a 99
Old May 1, 2006 | 12:39 AM
Kingpimp's Avatar
Nothing??
Old May 1, 2006 | 10:53 AM
Post
Not too sure about it being able to lock your doors when it goes into park or have the overide function.
I do know that when you change out your BCM module you will have to have the pcm reprogrammed to accept the new BCM module. Even if it is a new 99 BCM module the pcm still has to be reprogrammed. If you do not, the truck will not start at all. Nor will other functions work. The BCM module is linked with your anti-theft system.
I learned the hard way when I changed out a bad BCM module on my previous 2000 Silverado.
Jim
Old May 1, 2006 | 11:03 AM
Nick™'s Avatar
like the above is stated, however with HP Tuners you can relink the BCM with a couple clicks of the mouse - now whether it's gonna do what you want is another thing
cheyenne383
Nov 13, 2015 09:24 AM
lxcoupe
Aug 22, 2015 08:23 AM
Nimoryan
Jul 5, 2015 03:50 PM
Whippled 496
34
Oct 19, 2009 12:10 PM
1BadAction
Nov 25, 2007 09:15 PM
