Battery light
Battery light
Is there a way to turn off the battery light on a 2007 2500hd classic, I've done a Cummins swap on the truck, used a eztcu tranny controller, duramax ac compressor, the original 6.0 alternator, the truck will drive about 10 miles and battery light will go out, ac will then function like factory, turn truck off and back on light is back with no codes on voltage, charging 14.0 volts, I have hptuners with vats turned off, thanks in advance
