Bank 1 and Bank 2 Lean
Old Jan 31, 2007 | 03:54 PM
NegraRCSB2X4auto's Avatar
Default Bank 1 and Bank 2 Lean
I go these engine code monday Bank 1 and bank 2 Lean codes: 174 & 171
Now i ported my throttle body tuesday last week could this of caused that? Could someone just elaborate a little more on what could be causing this?
Old Jan 31, 2007 | 10:26 PM
shimp's Avatar
suprised noone jumped on this. Were you having any strange problems before porting the TB? If no wires loose etc probably hit some threshold with your current tune that made it go lean or think that it's lean. Reset it see if they show up again, call/email your tuner.
Old Feb 1, 2007 | 08:27 AM
I've deleted the code now and made sure everything after the maf is tightened down good. Just in case i had an leaks from there to the manifold.Everything was working fine before I ported the throttle body. But what wire should i check? plug wires?
Old Feb 1, 2007 | 08:43 AM
HWFSTRU's Avatar
I posted about this a little while back... here is the thread, I hope it helps:
https://www.performancetrucks.net/fo...d.php?t=383626
I started out with lean on bank 1 and then when lean on both banks... ended up being a bad intake manifold seal...
Chris
Old Feb 1, 2007 | 09:05 AM
blown3qtr's Avatar
Where are your LTFT's? I got the same code a couple of weeks ago. My LTFT's had creeped up pretty high. I changed my fuel filter and pump and it went away. I'm not sure if it was the filter or the pump that caused it. I was upgrading to an intank 255lph anyway. My theory is the reduced fuel pressure was causing the injectors to run just a little lean. combine that w/ increased airflow of a ported tb and BAM mil.
I would try changing the fuel filter and checking the fuel pressure first. These damn things always need a fuel filter so you really aren't wasting any time or $ doing that.
Old Feb 1, 2007 | 11:17 AM
bigbadwolf54's Avatar
13 Second Truck Club
fuel filter is always a good place to start...unless your truck doesnt have one, GM thought it would be a cool idea to stop puttin fuel filters on the frame rail in about 04,hey dodge does it why cant we
Old Feb 1, 2007 | 11:22 AM
I don't think my truck has a fuel filter i think i just have to change my pump. and ltfT don't know what that is sorry.
Old Feb 1, 2007 | 11:29 AM
ltft = long term fuel trim
yeah your filter is in the tank on the bottom of the pump assembly
Old Feb 1, 2007 | 07:33 PM
blown3qtr's Avatar
Oh yeah! I guess I should have read his sig.
madmann26
Apr 29, 2020 09:17 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
