AutoVE progess and some ?s (Newbie Tuner)
#22
Despite what has been recommended, you do NOT want to disable PE mode. BEN factors don't care what the commanded AFR is, it's a ratio of actual AFR to commanded AFR. If you disable PE mode, then you're sacrificing the thermal protection that extra fueling provides...
#23
Resident Retard
#24
This in effect does not disable it but places it in line with the commanded AFR in the [B3605] table , thus the PE does not effect the AutoVE process , correct ?
Why do you turn off COT then , because it effects the BEN mapping (modifies the AFR to richer attitude) , maybe I should have said setting PE at 1.0 or 14.63 disables the effect of the PE on the AutoVE process .
#25
Originally Posted by HD6.0l
Uh , from the tutorial it states to place PE at 1.0 , 14.63 correct ?
BlackGMC, I'll shoot you a PM shortly.
#26
#27
Originally Posted by Stoichiometric
That is a good point, how will PE be added without input from the MAF? Does the PCM command what is in the PE table and fuel from VE?
In a nutshell, the PCM determines the amount of air coming into the engine and applies the PE multiplier. This is either by calculation based on VE table value with respect to temperatures, rpm and map, or it's a combination of VE calculation and MAF reported, or entirely MAF, depending on conditions.
PM with more in-depth details has been sent.
#29
Actually, PE is a better method of providing high load fueling. Had you actually taken the EFI 101 course in NRH (I'm fully aware of why you wouldn't), you'd understand why.
Uh , did not say anything about high load fueling did we , I kind of know that one .
When doing AutoVE you want as little influence from other sources on the VE BENs as you can get .
That is why you set PE to 14.63 .
But after the AutoVE and MAF tuning , you want to go back and set the PE for high load power (12.8 to 13.0 NAE) .
Unless you are using COS then you can command what ever fueling ([B3647]) and don't need the PE mode at all .
#30
Originally Posted by BlackGMC
DC_Justin, how much is the EFI course? Coming to Texas anytime to teach it?
PM me if you think you'd be interested in going and I'll be sure to get you more details once they come out.
