Any spark plugs better than AC Delco?
Old Nov 27, 2012 | 10:04 PM
Slammed96's Avatar
Originally Posted by Onetogofast
I put the E3 plugs in the Denali about 10K miles ago and had it tuned at the same time. Notice no difference plug wise but have caused no problems and they were right around $3 each. I like chance that they are saving fuel by burning more but I have bought off a infomercial before lol
I'm surprised you like those. I had them in my last truck and it ran like *** with them in. Swapped for some stock style and made a world of difference. Most of the guys I work with steer away from them as well. That's just my .02 on them though.
Old Nov 27, 2012 | 10:54 PM
Mangled03gmc's Avatar
Baltimore Whore
Ac delco or NGK is the only plugs I will buy.
Old Nov 28, 2012 | 12:05 AM
1FastBrick's Avatar
Custm2500's Rude Friend
AC Delco FTW!!! I have seen the Cheap plugs cause problems.
Remember when they designed the spark portion of the system all the data they developed was based off using these brand plugs. Not all spark plugs are created equal. They use different core materials and that can effect the way the spark is distributed. In some cases the resistance can cause excessive feed back and burn the coils out.
Old Nov 28, 2012 | 04:35 AM
03sierraslt's Avatar
Same here
Old Nov 28, 2012 | 11:19 AM
Camin00's Avatar
I found NGK TR55-IX for $54 .060 gap what do yall think
Im also seeing plug wire size range from 7mm-10.4mm
The MSD are 8.5mm is larger wire better for more current flow or can going to large have a negative effect?
I guess what im mainly trying to ask is what is the perfect wire brand and size to get the most out of a product without causing damage to the coil or performance
Old Nov 28, 2012 | 01:04 PM
06Sierra2's Avatar
$54.00? Im running tr55's gapped at 50 in my truck. been great for 30,000ish so far.
Old Nov 28, 2012 | 01:44 PM
Camin00's Avatar
The TR55 are $18
The TR55 iridium are $54
Old Nov 28, 2012 | 09:53 PM
1FastBrick's Avatar
AC Delco iridium plugs $39 with free shipping on ebay...
For the wires AC Delco, Taylor, MSD
Shop around and see what you can find the best deal on.
Old Nov 29, 2012 | 05:57 PM
DR132's Avatar
i've found that chevy's are almost always happy with ac delco plugs, ngk's are also good. i've put a lot of autolites in customer's rigs because they're the most readily available at the local parts house and they work but i have had several fail inexplicably. not enough for me to condemn them but they're certainly not my first choice.
Old Nov 29, 2012 | 10:16 PM
sand man's Avatar
any body used autolites than me ?
