Any Michigan boosted ls tuners?
Old 03-01-2017, 12:37 PM
Gadgetized's Avatar
Originally Posted by smokeshow
I've been known to tinker...
Completely forgot you moved there. I would have smokeshow do it. Im not even sure Klug is doing it much anymore.
Old 03-01-2017, 01:06 PM
Registered User
BoostinJonnyukon's Avatar
Originally Posted by About20ninj45
It's that intake dbc or dbw?
Dbw I'm goin to dbc
Old 03-01-2017, 01:10 PM
Registered User
Originally Posted by FFDP
Junk the MAF and go straight speed density on a GEN 3 computer.
Wire in seperate IAT sensor.
Ok I have a gen3 2001 dbc pcm and harness
And have a separate iat to a gauge or?
Old 03-01-2017, 01:23 PM
FFDP's Avatar
The MAF is a 5 wire harness, use the two wires for the IAT and wire them into a new IAT sensor. Stick it in the air tubing or intake manifold and call it good.
BoostinJonnyukon (03-01-2017)
Old 03-01-2017, 01:25 PM
Registered User
Reliability is subjective in the aftermarket. All things considered it looks fairly conservative, so it may be a fairly reliable rig. As long as you show attention to detail to where its needed, you should be able to drive something like that for years.
Ok I'm also looking for someone to assemble my engine too when the time comes. Besides bearing clearances, balancing the lower end, rocker lash, valve spring set up, good oil flow in and out of the turbo and keeping that oil cooled, keeping iat temps down, properly tuned, what other areas can u think of being and issue?
Old 03-01-2017, 01:33 PM
Registered User
And in the tune of the pcm you will be able to read the second iat? Is this just for data or will the pcm use the 2nd iat too? Sorry didn't know I could add in new circuits. I guess this is a good time to say I'll be using hptuners
Old 03-01-2017, 02:32 PM
FFDP's Avatar
What second IAT?
The factory IAT is built into the MAF sensor, when you go to speed density and remove the MAF from the vehicle you have to add the IAT back into the system. Thus removing the 2 IAT sensor wires from the 5 wire MAF harness and wiring those to a "new" IAT sensor that you install in the intake tubing/manifold.
Old 03-01-2017, 03:06 PM
Registered User
What second IAT?
Ahh ok I got you now.
Old 03-01-2017, 11:21 PM
chevyboy.520's Avatar
Jake (smokeshow) tuned my truck and helped me an incredible amount. I'd trust him tuning any of my vehicles.
Old 03-02-2017, 05:28 AM
03sierraslt's Avatar
TJ@ Baker engineering is in Michigan also.
