Another REP Mode X-Link issue Thread........
Old Jan 21, 2013 | 08:31 PM
Gadgetized's Avatar
Try this. I didnt do much. I just mainly limited the throttle to 98.8 (where your TPS was showing), and enabled some codes to see if it shows something when it trips. Give it a try and see what happens.
File Type: tun
Old Jan 21, 2013 | 08:47 PM
Rhino79's Avatar
9 Second Club
What version efilive are you using? I dont even see the first 2 tables you changed...lol.
EDIT, I didnt have the damn v2 plugged up to see the red etc folder, sorry chance, hope this fixes it for you. Good numbers btw.
Old Jan 21, 2013 | 09:32 PM
Gadgetized's Avatar
Oops I'm in bed already. I will try to get you the version tomorrow. Two of the tables were the max throttle position that is at 98.8 max, and the update for the throttle position that GM did with the primary and secondary table. Those are the red folder that you need to have the flashscan plugged in to see. I know you are way more knowledgeable about EFI Live than I am. Are those the tables you were referring to?
Old Jan 21, 2013 | 10:11 PM
cdub81's Avatar
Thanks Gadgetized, I'll flash it and give it a shot. I've thought about still buying a LS3 90MM TB and swapping it. I def don't want this occuring while I'm sprayin' it.
Old Jan 21, 2013 | 10:15 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by BlackGMC
Who did the tune? I am betting your hitting the threshold on one for the tests. But then again i could be wrong.
Well i was wrong... Looking at the tune, the tests i was thinking of will never run....
Old Jan 21, 2013 | 10:33 PM
DrX's Avatar
DrX
Originally Posted by cdub81
So I bought another TB and hooked it up and everything was great! Fast forward a month and I change gears in the rear and go do some logging and truck starts going into REP at the top of 2nd or Middle of 3rd but it was never a cosistent rpm/mph etc.
I don't get any codes except some EBCM performance BS that's always there
Based on this, I would also check the speed sensor wiring for an intermittent connection if you can't find anything else.
New gears are 3.73?
Logged TP may be off a little if you log SAE.TP rather than GM.ETCTP
Log GM.TPDES to compare with GM.ETCTP ..... I believe there needs to be a 7% difference to trigger REP (P1516)
Re-enable P1516 and P2135 in your tune so that you can see if they are being triggered. (looks like they have been disabled) If disabled, REP will could still be triggered, but the codes will not be reported.
Old Jan 22, 2013 | 05:16 AM
Gadgetized's Avatar
I re-enabled several different codes to see if the problem can be identified while logging in the tune I posted up. When I was having all my problems I turned them off in my tune too, and you still get REP, just no codes. Like you said, it doesn't help at all to turn them off.
Old Jan 22, 2013 | 05:50 PM
DrX's Avatar
DrX
Set 1516 and 2135 to "1 Trip" so that they pop up right away if a fault is detected.
Old Jan 22, 2013 | 07:36 PM
cdub81's Avatar
Ok will do, probably will be this weekend before I can play with it. I'll post up what I figure out and go from there. Thanks for the help fellas
Old Jan 22, 2013 | 07:40 PM
cdub81's Avatar
New gears are 3.73?
Yes new gears are from 4.10 to 3.73
