Almost 140K on stock O2s
Old Dec 17, 2009 | 05:32 PM
black00chev's Avatar
Slowest turbo build ever!
If i have the aeroforce gauges what should i look for to make sure they are on point? My truck seems to be gettin a little lazy as well.
Old Dec 17, 2009 | 09:59 PM
fastrt's Avatar
11 Second Truck Club
I have been thinking the same thing. I bumped bank 2 when i was taking out the y pipe last week, and have been watching it, but it seems to be working fine.
Old Dec 17, 2009 | 11:56 PM
Wheatley's Avatar
Truck Sponsor
I would personally replace them anyway!!
Old Dec 18, 2009 | 10:00 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by 00ChevyScott
How do you like the speed density tune? More consistent power? Mine loves to run good with a new tune, but after some miles it gets shitty.
I am not running a SD tune, i am running OpenLoop Maf, which means i am not running any trims... Mainly so i can command a leaner mixture in the cruise areas....
Your problem IMO is learning (PCM not your Intelligence) and not tuning the MAF and VE table... The reason i say this is because the way the VE table influences the airflow calculation while the MAF is turned on...
reason behind my thinking, look at the definition of B0120
Originally Posted by B0120 - RPM Threshold for Airflow Calculation
If engine speed is less than this value, then the PCM uses a dynamically calculated airflow value to determine grams of air per cylinder.
While the airflow is in a "steady state", then a correction factor is updated based on the airflow difference between the MAF sensed airflow and the MAP calculated airflow.
During rapid changes in airflow, the correction factor is applied to the airflow calculations to compensate.
If engine speed is above this value, then the PCM will use the MAF sensor exclusively (if not disabled by DTCs) to calculate grams of air per cylinder.
No updates are made to the airflow correction factor.
So let me try to explain that. While your driving around the computer is calculating the difference between your MAF airflow and your VE airflow calculations/readings... This difference is added to the final airflow calcuation. Which if they are not BOTH tuning/scaled/adjusted properly there will be a difference, as time goes by this difference grows and it is added to the airflow calc. Thus making your airmass wrong, which makes your reference the wrong timing value... On a NA tune, TIMING=POWER(hp)....
Make sense....
Originally Posted by GMCtrk
Go SD, without a doubt.
I don't think that is a good idea, he is not out flowing the MAF so no need to take it out of the airmass calcuation logic... IMO people who suggest this are not tuning the MAF and VE correctly (no offense).... As long as your not outflowing it, the screen is still attached and it is working properly, then there is NO REASON TO REMOVE IT
Old Dec 18, 2009 | 10:12 AM
00ChevyScott's Avatar
Wearin' da big hat
That makes sense corey. Once I figured out why the hell my wideband isn't working, and get it wired right to hook it up to EFILive, I will start working on it. I have a few days off next week, so I'll probably get to work on it then.
Old Dec 18, 2009 | 10:17 AM
BlackGMC's Avatar
Resident Retard
I believe i will be off mon-Weds next week if you want to stop by....
Old Dec 18, 2009 | 10:30 AM
Wearin' da big hat
Sounds like a plan
Let me know when you're not busy with the Wife, I know it's xmas week so you've probably got a lot on your plate already haha.
Old Dec 18, 2009 | 10:32 AM
BlackGMC's Avatar
Resident Retard
Sounds like a plan
She leaves Saturday mid afternoon ....
Old Dec 18, 2009 | 10:36 AM
Wearin' da big hat
Haha sweet. Gonna send you a PM in a sec
Old Dec 19, 2009 | 09:18 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by dc_justin
How do they look as they warm up? Once they start moving, do they immediately hit their full range (0-900) or do they start oscillating by 50-100mv, then slowly work their way up to full oscillating range?
+1...if they're lazy like you said, I'd replace them
