Air Fuel Ratio
Old Jun 29, 2006 | 01:22 PM
  #41
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by 02sierraz71_5.3
I understand that Im not challenging what your saying about stoich afr. What I am challenging is the use of the word "perfect" as the definition explicity states
"Completely suited for a particular purpose or situation" Blown chevy made a statement that 14.7 is the perfect afr, if he simply ment that its stoich duck a dur this is obvious. I thought that he was stating that its the best afr to run and his statement was so blanketed it left room for discussion which is what Im doing.
Im discussing different AFR ranges and thier inherent benefits. Egos arent in the way its point counter point thats what a discussion is.
The word perfect was based on the Stoich theroy. Again, I dont think you understand the basis of the thread......
Old Jun 29, 2006 | 01:25 PM
  #42
dc_justin's Avatar
Hello Dave
English language is a crazy animal.
Though, in a perfect world/engine/scenario, you would see no performance benefit whatsover from running richer than 14.7, it would be just a waste of fuel and a slight power decrease as the cooler burn would result in a lower pressure.
Old Jun 29, 2006 | 02:38 PM
  #43
Yelo's Avatar
- BACK ON TOPIC -
At what point does a mixture run TOO RICH in relation to what it should be....I mean, we all know that 10:1 AFR will start to wash cylinder walls down, but at what point does it become too rich to be safe ???
Old Jun 29, 2006 | 02:45 PM
  #44
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by Yelo
- BACK ON TOPIC -
good question.
Old Jun 29, 2006 | 02:55 PM
  #45
dewmanshu's Avatar
Moderately Differentiated
- BACK ON TOPIC -
I think there is waaay too much room for debate in that quest. Waaaay too many variables play a roll in that. Generically speaking, one could assume at the point where "rich" isn't too many fuel molecules anymore...at the compression stroke you have a liquid fuel in the mix, not atomized. The very edge of where the air molecules air aren't enough to cause combusition. What exact ratio is that? That would be hard to determine wouldn't it?
However, doing a little reading on the explosive limit of gasoline, it has a upper and lower limit.
http://en.wikipedia.org/wiki/Explosive_limits
I thought the octane rating would affect this, you'd think at least. But with this knowledge, we can conclude (guess, at least me ) that 10.5:1 is a bad scenario. (Gasoline's Lower Explosive Limit is 1.4%. 14.7/1.4 is 10.5) I just made that up, LOL sound alright for speculative? Souds good to me, stay away from 10.5:1 with gasoline!
Old Jun 29, 2006 | 02:57 PM
  #46
bomariam1's Avatar
this the seconde time that I send this thread (I don't know why it wasn't entered?), any ways.
why we are discussing since every one agree that in a "perfect world" 14.7 means 100% fuel burned?
it's better to discuss what is the best AFR for any application.
Old Jun 29, 2006 | 03:01 PM
  #47
XLR8NSS's Avatar
Adkoonerstrator
14.7:1/stoich was being discussed because some people did not know what it was.
Old Jun 29, 2006 | 03:06 PM
  #48
dewmanshu's Avatar
I was thinking about ethanol, looking at that chart its LEL is 3%!!! I guess that ruins my hypothesis for a formula... 14.7/3=4.9! LOL
I think I got it backwards.
***Yeh backwards,
There are two explosive limits for any gas or vapor, the lower explosive limit (LEL) and the upper explosive limit (UEL). At concentrations in air below the LEL there is not enough fuel to continue an explosion; at concentrations above the UEL the fuel has displaced so much air that there is not enough oxygen to begin a reaction. Concentrations of explosive gases are often given in terms of percent of lower explosive limit (%LEL).
So, this mean when the air/fuel mixture is 7.6% of fuel, it becomes unignitable? Hence washdown?
Old Jun 29, 2006 | 03:10 PM
  #49
dc_justin's Avatar
Hello Dave
Yeah, the units aren't exactly right for that.
I'd think that 3% would be 3% of volume as the limit... 100% / 3% = 33.3:1
Same with Gasoline
Rich Limit: 100/7.6 = 13.1:1 Lean Limit: 100/1.4 = 71:1
Compression has a big effect on these numbers as well, I'm just not certain how much.
Old Jun 29, 2006 | 03:11 PM
  #50
dewmanshu's Avatar
Same with Gasoline
yeh, i am just trying to throw stuff on the table that seems that it would affect the wash down. Hmmmm.
