AFR not what commanded- lean no matter the changes
Old Apr 12, 2009 | 12:08 AM
nonnieselman's Avatar
Default AFR not what commanded- lean no matter the changes
USING EFI LIVE
Anybody,
no matter what i change or try to command the actual AFR will not change.
I added 20% across the higher half of the Main VE and nothing happened.
Whats the deal?
I have ran out of ideas and im clueless. Need help.
Here is the tune and a log.
Tryin to go Speed Density, Tried to go back closed loop from a old tune that worked. It had no changes and now its lean and not richening up when the PE settings are met..
File Type: efi
File Type: tun
Old Apr 12, 2009 | 12:55 AM
Whippled 496's Avatar
You need to command something other than 14.68 in those cells in table B3605. Even though your in speed density, commanding 14.68 will result in defaulting back to using your trims (its a weird EFILive thing). Change your 14.68's to 14.75's or something then adjust your VE table accordingly and see how that works. If i remember it mentions something in more detail about this in the Closed loop to open loop tutorial.
Old Apr 12, 2009 | 12:59 AM
GMCtrk's Avatar
why is every tune I load up in EFI live showing in kilometers per hour instead of MPH? How do I change that?
Old Apr 12, 2009 | 01:13 AM
You need to open:
Edit -> Configure display units
Then adjust the specific data, rows, and columns between metric and imperical accordingly. Some tables you may want to have a combination of Metric AND imperical. Just right click on the table line you want to make adjustments to and change either the rows, columns, or data........or any combination of the three. For example in table B5911 you may want the column to be metric (grams/Cylinder) and rows to be imperical (fahrenheit).
Old Apr 12, 2009 | 01:14 AM
viciousknid's Avatar
Where's the Beef?
Don't have my laptop with me but its under Edit: configurations or something like that toward the bottom of the edit list.
I just make it all imperial and then when I see something that needs to be metric I change just that back to metric.
Old Apr 12, 2009 | 01:21 AM
GMCtrk's Avatar
Im really liking your torque converter lock up points in 4th nonnie
Old Apr 12, 2009 | 10:20 AM
dc_justin's Avatar
Hello Dave
USING EFI LIVE
Anybody,
Whats the deal?
Do you perhaps have an air leak just before the O2 sensor?
Old Apr 12, 2009 | 11:07 AM
lownslo's Avatar
we looked for air leaks but no luck. We are stumped? im going to pull the cai off today and see if it might be leaking from a boot! no exhaust leaks at all! It was running fine then he tried to smooth out some lean spots and now the whole table goes lean. I roll on the throttle and it richens up then right back to lean!
Old Apr 12, 2009 | 11:20 AM
mred's Avatar
lownslo06,
just a question, have you replaced the O2s?
Old Apr 12, 2009 | 05:39 PM
when i did the free air calibration i checked for an exhaust leak just to rule that out and we checked the fuel pressure.
Whippled: i have B3605 setup similar to the tutorial. i do see i need to have a small ramp in the fuel tho. its 14.62 like the tutorial shows.
i just changed aome stuff in the tune and goin to try this again tom i guess....
thanks for yalls input. ill post up what happens.
