ABS and TC on
after i added the lowering control arms my truck threw a abs and traction control light.
modi us showed rough ride detected. i could clear code and be sitting there not moving and it comes right back.
sometimes when driving around it will go away and come right back. and sometimes when hitting the brakes it turns off and pedal gets hard like it use to be then it goes away and pedal goes down then back.
in the end i look like a idiot coming to stop sometimes lol. also I'm tired of a christmas tree dash.
any ideas?
any ideas?
DTC's?
If it wasn't doing this before you worked on it, you have likely forgotten to plug something in, or you've damaged a harness/connector/sensor, etc. If you can read the DTC, it may tell you which wheel to check first.
Rough Ride Detected? I'm not familiar at all with the 2WD SSS, does it have an active handling system, or stabilitrak? Are your shocks electronic, with connectors at the top, or does your truck have ride height/yaw sensors?
I have traction control and none of those others. It's had spindles on it before but I switched with these. I have brake fluid in it. And it doesn't leak anywhere.
I wish it would just throw a code and be done with it
