90mm/ WCHH J-tube/Dr X mod
Old Jun 3, 2007 | 02:23 PM
2004SSS's Avatar
ok well went and hooked it up made it look all perty and for the first time in 6 moths i hooked up the battery cables. beside the 10 codes i found the tb worked but only for a second. it did the little flip for the test and when i had it in the run position in park it opened 100% but then went into reduced power. i think because i dont have my map, evap, low volatage and quite a few toher things so im not 100% sure it will work yet.
Old Jun 3, 2007 | 09:25 PM
DrX's Avatar
DrX
It's not designed to work with the SSR TB that you are using. But you can try jumping the grey wire on each side of the X-Link and see what happens. That will be as close as you will get to making it work with that TB. If that doesn't work you might require a slightly higher +ve reference for the pink wire.
Old Jun 3, 2007 | 09:37 PM
2004SSS's Avatar
yeah i didnt try to get it to open any less than 100% im trying to find a ls2 tb but i just hope i dont run into clearance problems . but it looks like if i mount it with the motor to the passenger side i will be ok.
Old Jun 4, 2007 | 02:01 PM
Holty's Avatar
Notorious BIG
congrats bill, looks awesome
Old Jun 8, 2007 | 10:04 AM
krambo's Avatar
Anyone do any logs to see the impact of the extra +/- 10% TB swing? If so, whatcha find?
madmann26
Apr 29, 2020 09:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
