90mm TB and X link issue
Just installed a edelbrock pro flo intake and 90mm LS3 throttle body with the x link. The x link is a month old, brand new and is the very newest version. The problem im having is no throttle response. When key turned in, the TB will flutter slightly, then go closed. When trying to start, it fires up for a second then dies. Pressing accelerator peddle doesn't do anything. But since it does have movement when key is turned on, that leads me to think it is getting signal. I could be wrong tho. Any help would be appreciated
Any trigger wires tapped into the throttle wiring?
http://torquerush.com/GM%20Electroni...leshooting.pdf |
Yes there is
Try disconnecting it and flipping the key to on to see what happens.
I'll give that a try. Thank you for the help. I'll post back up with the results as soon as i can
Anything else I could look into other then that?
Are there any DTCs set? Battery fully charged? Ground wire for engine harness secure at the top, right, rear of the block?
Says engine reduce power on display. Does have check engine light. I'll have to read them and see what I got
Everything is hooked up right, grounds are all on, all plugs are connected.. I've also added ev6 injectors with the adaptors. The intake, TB and injectors are all new to engine.
Originally Posted by 2doorfury
(Post 5209037)
Any other 2003-2007(classic) trucks around that you can plug the TB and X-Link into to see if it operates? |
| All times are GMT -5. The time now is 01:02 AM. |
