8.1 injectors and strangness
Old Jul 16, 2005 | 08:59 PM
02sierraz71_5.3's Avatar
Default 8.1 injectors and strangness
1st
I was at 120% duty cycle on injectors so I swapped out the 5.3 stockers for some 8.1l injectors. At the time I was running SD and noticed a good 20-30% duty cycle drop (still could have gone bigger) but these should be satisfactory. Anyway seeing around 17 ms wot instead of 22-25ms with the old. So I finish tuning some SD and turn on the maf and guess what duty cycle goes right back up to around 22ms 120% wot. WTF so Im thinking I need to tweak the maf table.
2nd
Something else strange I noticed today was that running SD my 02 voltage is all over the place at part throttle jumping around by differences of 300 mv then hook back up the maf and its not anywhere near as spuradic varying difference of about 150 mv. Trims levels are about the same SD and with maf.
3rd
strange observation remember Dewanshu's post about the pcm dropping packets well today it is was dropping em like its hot and it was doing it wot. I noticed my fueling would go scary lean like around 180 after it did this.
has anyone found a solution to it dropping packets could it be running hp tuners is causing it?
Old Jul 18, 2005 | 12:15 PM
anyone have any other ideas on inj pulse width increaing with maf vs SD
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
OHsixLS3
Sep 25, 2015 11:20 AM
jroctpb
Sep 16, 2015 09:05 PM
