8.1/Allison 5sp Swap into what?
Old Jul 29, 2024 | 01:56 PM
strutaeng's Avatar
5 Year Member
I ordered a TCCM for my harness. I'm going to plug it in and delete VATS and try to see I can get the engine fired up on the ground. Hopefully it is good runner.
Does anyone know what is required to convert the engine/transmission to a 4x4? I'm either thinking of swapping the rear gear train on the 2wd transmission or simply swapping to another 4x4 transmission. I bought myself the ATSG manual for the Allison and some other book from SA books.
Does anything on the engine tune need to changed to be reflashed to make it 4x4? Or is it just things like power from fuse block powering things like the transfer case and front axle actuator?
I guess I need to start looking at wiring diagrams at charm.li to see what I find.
Old Jul 29, 2024 | 09:59 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You have to stand the trans up on end and swap the rear tail housing with shaft to the 4x4 variant. Need to to be straight up and down as I believe there is a spring or lever that can move out of place back there. Its posted on some of the diesel sites
Old Jul 29, 2024 | 10:07 PM
strutaeng's Avatar
5 Year Member
Also, does anyone know if the dual tank setup can be added to the truck ECUs? I was looking my suburban's tune on HP Tuners and it has these settings:
Old Jul 29, 2024 | 10:14 PM
1FastBrick's Avatar
can segment swap it in. The diesel guys do this finding a compatibale segment to swap is the hard part.
Old Jul 30, 2024 | 10:14 AM
_zebra's Avatar
makes children cry
just spitballing with no HPT experience at all: can a corvette segment swap in? the C5s have dual gas tanks.
Old Jul 30, 2024 | 10:16 AM
shakenfake's Avatar
Shlumpt
5 Year Member
That is an interesting idea
I also did not know that C5s had dual gas tanks.
Old Jul 30, 2024 | 11:33 AM
strutaeng's Avatar
5 Year Member
Yes. I remember watching this video and the guy talking about the dual tank setup:
Old Jul 30, 2024 | 12:30 PM
_zebra's Avatar
makes children cry
yeah - the center tunnel is in the way, so it's got one tank behind each seat with a cross-over tube/pump. it fills & displays as if it's one tank to the operator.
Old Jul 31, 2024 | 09:50 PM
1FastBrick's Avatar
Corvette is not a true dual tank though.
Old Aug 1, 2024 | 11:42 AM
_zebra's Avatar
makes children cry
that's sorta what i meant, though. it is comprised of two physically-separate containers that are interconnected via a balance tube, filled from one port, and summed to provide one total fuel reading.
this ain't like a 80s C/K10 that has two independent tanks where the fuel lines and gas gauge run off a toggle switch.
my impression was that the HPT question referred to the 1st situation.
Yuke60
Sep 23, 2011 03:34 PM
BLAQ DENALI
Dec 13, 2005 12:24 AM
Will
May 21, 2004 09:42 PM
PSM
Feb 19, 2004 08:04 PM
DERTY
Oct 21, 2002 01:30 PM
