4L80E Lockup Tuning Woes
Old Dec 6, 2015 | 07:36 PM
lycominghunter's Avatar
Default 4L80E Lockup Tuning Woes
I have a segment swap done on my turbo 4.8l with a stock 4l80e with a triple disc 258mm circle D 3600 stall converter. After today's outing at the track, I had some questions (Tune, Config, and log attached).
Of note:
**I am commanding the converter to lock in 2nd and 3rd gear.
**I am utilizing the tow haul button and its respective tables for my track passes, so if looking at the tune be sure to look at the "performance" transmission tables.
1) I am commanding the converter to lock after the 1->2 shift (it appears the lockup mph is based off the ISS, and it locked mid 1->2 shift). The converter locked in 2nd, then unlocked at 71mph, then locked again at 84mph. Why?
2) I have shift lock disabled, however the converter is staying locked during at WOT through the 2->3 shift. What should I change to have the converter unlock for the shift?
Despite the transmission issues, the truck ran a new PB of 11.59sec@115.9mph.
Thanks for the help!
File Type: hpt
File Type: cfg
Old Dec 10, 2015 | 08:40 PM
Nobody?
Could it be a solenoid or internal issue that may be responsible for the converters locking/unlocking at WOT?
Old Dec 11, 2015 | 12:31 PM
DrX's Avatar
DrX
According to your TCC Slip % there is no lockup in that log when you are rolling at 100% TPS...slip % stays high.(can you log TCC Mode with HPT?..Off, Enabled, Applying, Locked, etc). And how is there 0% slip when you are holding it at 3500RPM/ 0MPH on the brake? Something is not right.
Old Dec 13, 2015 | 06:32 PM
Thanks for the response Dr X.
I haven't done too much logging for transmission parameters until I started tuning WOT lockup speeds.
The TCC% slip is definitely wrong. In the log, when PWM is 99-100% the converter is locked.
Any thoughts as to what the issue could be, or even how to diagnose it?
Thanks!
Old Dec 13, 2015 | 06:57 PM
DrX's Avatar
DrX
Did you double check the ISS wiring?
Was the Seg swap done with 2.25 Beta?
Yes, it should be locked at 99%. I would log more trans parameters....ISS, VSS, TCC Mode, Gear, Slip RPM, Engine RPM, etc.
Old Dec 14, 2015 | 08:40 PM
Yes. It was swapped with 2.25 Beta...is that good or bad? HA! I'll do some more reading, log more parameters, and see what I can come up with.
Appreciate the help man!
Old Dec 15, 2015 | 01:44 PM
DrX's Avatar
DrX
Should be good...have seen some people just copy/paste tables and think they did a seg swap. I built myself a tune with 2.25 Beta but never got a chance to try it out. Had been running on EFILive til now.
speedracer2536
Sep 29, 2016 09:44 AM
jakes4321
Dec 17, 2015 11:21 PM
slowec
Nov 8, 2015 08:24 PM
Troy5061
Oct 15, 2015 02:35 PM
