4.8pcm the same as 6.0 pcm
Old Aug 7, 2006 | 07:28 PM
Mangled03gmc's Avatar
Baltimore Whore
Default 4.8pcm the same as 6.0 pcm
Ok guys i am sorry for all the ??? here lately but I am getting ready to do the swap. Is the 4.8 pcm the same as the 6.0 or is tables and things different in them.. I am aware that a custom tune will solve the problem but till I can get one I need to go this way. Thanks, if there is any other things i should no tell me.. Thanks for the help JOHN
Old Aug 7, 2006 | 07:34 PM
Wilde Racing's Avatar
How do I change this text
The tables are way different. about the only table that is the same is the IFR table...........
Old Aug 8, 2006 | 11:22 PM
Pcm is different as well as most of the numbers in the tables as well. I did this swap over a year ago and have made out fine. You will need custom tuning to update the engine size. Depending if you are using different injectors or keeping the 4.8's (which I did and are the same as the 6.0's in the later years) you will have to change the injector control and flowrate for them.. From there you can tune the 4.8pcm and now it will be like the 6.0 one...
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Wrecker 426
Sep 30, 2015 09:39 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
