4.8L 9psi Tune Advice
20 * isnt really alot for a 4.8 figuring 29 * for NA and safely pulling 1* per 1psi
My old 5.3 when was on 9 psi had 22* in it on 93
Made 575rwhp
Plugs dont lie but will agree creep up on that number but is very plausible to run
If youre on e85 you could get away with delaying pulling timing to about 5 psi then start the 1* per 1psi
Also since youre turbo you have more leg room then a Pd blower
Made 575rwhp
Custm2500's Rude Friend
Another tuner, claimed he pushed a bone stock LQ4 with 31 degrees of timing on an Engine Dyno.
He Claimed to get 56 HP over stock out of it at 31 degrees with the fueling dialed in. In another sentence below that he says he might have gotten more but the Wide Band on the Dyno wasn't working right...
Although I am not a tuner by any means, I haven't seen many NA combos pushed past that 28-30 mark that lasted very long on pump gas.
Formerly ScreamingL
My 5.3 in my jeep took 30* and showed power gain
Skeets old 6.0 that held the record for fastest NA 6.0 took 29*
4.8s take timing with having no compression and then adding a cam drops dcr
Another 6.0 i tuned made 480 with 29*
Various dynos used and different tracks to back up
Now newer motors dont take the timing....most ls3s take 26*
Formerly ScreamingL
another example....my old 5.3 with a 230/236 cam....at 22* truck trapped 126 mph on 12.5 psi, kept upping timing and kept gaining mph....at 26* timing it trapped 130 mph
went to 27* and it was faster up to the 330 where clutch pedal broke
this was on 93 and meth
never pushed a drop of coolant, plugs looked good being br7ef...afr was 10.8-11.0 during run
so in the end you gotta read plugs to tell what is safe and what isnt...
Well good to know that something is off with that 2.08 60ft, so I think I know where to start. Suspension should be good, but I'm going to go back through and make sure the front and rear cycle freely (double nut the bolts). I can play with the single adjustable qa1's as well. Lastly, and I still think its off, will be the pinion angle. I shimmed it so that under acceleration, the pinion would rotate up to match the angle of the trans (trans is at -5 degrees, pinion was at +3, accounting for 2+ degrees of upward rotation under acceleration). But I'm going to set the pinion at -2 and see if that works out better.
I'm on 93 pump gas.
Definitely not jumping straight to 20 degrees, but will probably creep up to about 16 or 17. Yes, Ive been making sure the AFR is accurate before increasing the timing.
N/A, my truck ran a best of 14.39@96.5mph on 21 degrees (converter, 3.42s, stock exhaust manifolds, isky triple 12, e-fans, CAI). I increased the timing into the high 20's and never could pull off a better time - so kind of interesting.
Also, with regards to the M/T ET Streets, I've ran them anywhere from 20 to 14 psi. 20 psi didn't seem to hook very well but maybe that's because of the suspension issues.
So, definitely got to figure out the suspension so that I can leave under some boost and get at least down to 1.7 60fts. Id like to get some high 11's out of it on 9psi before increasing the boost.
Thanks for all of the help guys!! I really appreciate it.
I'm on 93 pump gas.
Formerly ScreamingL
I'm on 93 pump gas.
I'm on 93 pump gas.
What is timing at 1.1 load?
What afr at 2 psi?
What afr at 5 psi?
George, not sure what you mean about 1.0 and 1.1 load.
My AFR in boost is 11.5 commanded, but always stays between 11.4 and 11.7.
Are you suggesting to have transition AFR at 2 and 5 psi? Should AFR at 2psi be about 13.1, and at 5psi 12.3? (or something along those lines?)
