2006 Predator Programmers Are Available!
Old Nov 16, 2005 | 10:18 AM
tbyrne's Avatar
Default 2006 Predator Programmers Are Available!
Diablo has just released their new Predator programmer for the 2006 gas trucks -
The Predator for 2006 GM V8 Truck & SUV (part no. U7192) is a state-of-the art high performance tuning flash programmer, which advances the timing, optimizes the air/fuel ratio and remaps the transmission shift points (in automatic transmissions). Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
U7192 will program -
2006 Chevrolet Silverado, Tahoe, Suburban, Avalanche
4.8L, 5.3L, 6.0L
2006 GMC Sierra, Denali, Yukon
4.8L, 5.3L, 6.0L
2006 Cadillac Escalade EXT, ESV
2006 Hummer H2
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle. Because we allow for timing and fuel adjustments the end user can optimize the tune for his/hers specific vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predator's live data feature to monitor timing and other vital parameters.
The Predator allows the end user to adjust the following parameters:
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management ON/OFF adjustment
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Injector Adjustment
Adjust for different injector size
Adjust for long term fuel trims
Catalytic Overtemp protection Adjustement
Disable P0430 and P0430 codes
Adjust COT enable temperature
Multiple Misfire P0300 adjustement
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
EGR disable
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
AIR code disable
Disable P-codes: 0410, 0412 and 0418
Rear 02 disable code
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
Transmission functions do not apply to trucks with the Allison transmission.
The Predators diagnostic features allows end user scan and erase fault codes as well as monitor live data while driving. Predator can read and erase fault codes, and contains all the manufacturer specific P codes.
Our price for this programmer is $399.99. This includes free overnight shipping to you (48 states only). Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
TBYRNE Motorsports is an authorized DiabloSport dealer. Diablosport does NOT offer a manufacturer's warranty for products purchased from any company that is not an authorized dealer.
Have a good day!
ORDER LINE - 1-877-4-TBYRNE (1-877-482-9763)
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR CURRENT SPECIALS and PRICE MATCH PLUS POLICY!
WE HAVE YOUR FORCED INDUCTION NEEDS COVERED WITH - ATI, VORTECH AND MAGNUSON SUPERCHARGERS ALONG WITH STS TURBOS!
Old Nov 17, 2005 | 08:57 AM
BLACKND's Avatar
Looks as though they are a lot more versatile than ones I've seen in the past. How does that work with the Torque Management removal or reduction though. I believe in the past, didn't you have to recieve custom tunes for this via internet from predator? Or are all these settings listed above in the ad, available to change parameters directly from the handheld?
I would like to tune my new Z71 slightly, not like the crew cab I had, which was highly modded. this just might fit the bill, my main concern is getting rid of some of the torque management, and maybe playing around with the shift points a bit.
Also, how long is this price good for, or is this the all the time price?
Old Nov 22, 2005 | 08:40 AM
tbyrne's Avatar
The parameters listed come with the tuner. They can still do custom tunes if needed. The $399.99 with free shipping is our everyday low price
BlownHD
Oct 3, 2015 12:24 PM
Cammed4ever
Sep 30, 2015 03:38 PM
bisqikss
Sep 27, 2015 09:40 PM
OVOAustin
Sep 15, 2015 08:32 PM
jtphelps289
Sep 1, 2015 08:58 PM
