2002 Trailblazer with 6 cyl camshaft code
Old Apr 15, 2008 | 06:38 AM
dewmanshu's Avatar
Moderately Differentiated
Default 2002 Trailblazer with 6 cyl camshaft code
[PCM] P0340 - Camshaft Position (CMP) Sensor Circuit (SES) (Pending) (History) (Current) (Immature)
wtf?!?! Bad wire? bad sensor? pretty odd code. It has 110K miles on it. I swear I haven't done any modifications to it. My mom's dodge neon had a camshaft sensor code and it started running like sheet. It turned out to be a burnt wire on the sensor. It had 200K miles on it. The TB runs fine. Could it be just a wire? Anybody have a camshaft code pop up on a non-modded or just bolt on mods vehicle before?
Old Apr 15, 2008 | 12:19 PM
Zick's Avatar
I thought the Pending/Immature meant that it was an old code.
Have you tried clearing it and see if it comes back? Could have been a fluke.
Old Apr 15, 2008 | 01:25 PM
dewmanshu's Avatar
It's my wife's, she said it popped up yesterday morning. I could have sworn I saw it a few months ago...could of sworn. Between the stress at work and my liquid medicine I don't recall though. Nevertheless, it is pretty new. Where is the cam posit sensor on these 6 cyl's?
Old Apr 15, 2008 | 02:59 PM
Grumpy5.3's Avatar
The camshaft position (CMP) sensor produces a 6X plus a sync signal for each revolution of the exhaust camshaft. These signals are for control of sequential fuel injection and for exhaust camshaft phaser control. The CMP is connected directly to the powertrain control module (PCM) and consists of the following circuits:
• A 12-volt reference
• A low reference
• A CMP sensor signal
If the CMP Active Counter stops incrementing, DTC P0340 will set.
Conditions for Running the DTC
The engine is running.
Conditions for Setting the DTC
The CMP Active Counter is not incrementing.
Action Taken When the DTC Sets
• The malfunction indicator lamp (MIL) will illuminate after two consecutive ignition cycles in which the diagnostic runs with the fault active.
• The PCM records the operating conditions at the time when the diagnostic fails. This information stores in the Freeze Frame and Failure Records buffers.
• A history DTC stores.
Conditions for Clearing the MIL/DTC
• The MIL will turn OFF after three consecutive ignition cycles in which the diagnostic runs without a fault.
• A history DTC will clear after 40 consecutive warm-up cycles without a fault.
• Use a scan tool to clear the DTCs.
Diagnostic Aids
• Whenever the PCM sees less than 15 resyncs in 256 seconds, the counter resets to 0. When a poor connection is present, the cam sensor active counter stops incrementing and the cam sensor resync counter starts to increment.
The following conditions may cause this DTC to set:
- Damage to the camshaft reluctor wheel
- Damage to the CMP sensor
- The sensor coming in contact with the reluctor wheel
- Foreign material passing between the sensor and the reluctor wheel
• If the condition is intermittent, refer to Intermittent Conditions .
Test Description
The number below refers to the step number on the diagnostic table.
This step tests the output of the CMP sensor. If the duty cycle is not within the specified range the sensor is bad.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Powertrain Control Module Connector End Views or Engine Controls Connector End Views
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
Start the engine.
Observe the CMP Active Counter parameter with a scan tool.
Does the scan tool parameter increment?
Go to Step 3
Go to Step 4
Observe the Freeze Frame/Failure Records for this DTC.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
Did the DTC fail this ignition?
Go to Step 4
Go to Diagnostic Aids
Turn OFF the ignition.
Disconnect the camshaft position (CMP) sensor.
Turn ON the ignition, with the engine OFF.
Measure the voltage from the 12-volt reference circuit to a good ground with a DMM. Refer to Probing Electrical Connectors in Wiring Systems.
Is the voltage more than the specified value?
10 V
Go to Step 5
Go to Step 7
Jumper the CMP circuits from the CMP sensor to the CMP sensor harness connector. Refer to Using Connector Test Adapters in Wiring Systems.
Turn ON the ignition with the engine OFF.
Measure the voltage drop from the low reference circuit of the CMP sensor to a good ground with a DMM. Refer to Circuit Testing in Wiring Systems.
0.2 V
Go to Step 8
Go to Step 6
Leave the jumper wires installed.
Remove the jumper wire from the CMP signal circuit on the powertrain control module (PCM) side.
Start the engine.
Measure the duty cycle from the CMP signal circuit on the sensor side and to a good ground with a DMM.
Is the duty cycle within the specified range?
40-50%
Go to Step 9
Go to Step 10
Test the 12-volt reference circuit for an open, high resistance or a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 15
Go to Step 11
Test the low reference circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 15
Go to Step 11
Test the signal circuit for an open, short to ground or a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 15
Go to Step 11
Test for an intermittent and for a poor connection at the CMP sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 15
Go to Step 12
11
Test for an intermittent and for a poor connection at the PCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 15
Go to Step 14
Remove the CMP sensor.
Visually inspect the CMP sensor for the following conditions:
• Physical damage
• Loose or improper installation
Go to Step 15
Go to Step 13
13
Replace the CMP sensor. Refer to Camshaft Position Sensor Replacement .
Did you complete the replacement?
Go to Step 15
14
Replace the PCM. Refer to Powertrain Control Module Replacement .
Go to Step 15
Clear the DTCs with a scan tool.
Start the engine.
Go to Step 2
Go to Step 16
16
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Old Apr 15, 2008 | 03:20 PM
dewmanshu's Avatar
thanks grump!
Old Apr 20, 2008 | 07:54 PM
oldred95's Avatar
Unplug the camshaft position sensor connector and see if there is oil there. Its located on the right front corner of the cylinder head. I had one that was leaking oil back up through the sensor and into the connector and although it was still working every sensor I've ever seen do that eventually goes bad.
Pimpinpete
43
Dec 22, 2017 08:13 AM
Tydriver
45
Oct 23, 2015 09:19 PM
sTNT971
Sep 26, 2015 04:22 PM
bisqikss
Sep 8, 2015 03:35 AM
RONIN LSX
Sep 5, 2015 10:55 AM
