2002 Avalanche Electric Fan Conversion Not working HELP!
Old Oct 27, 2011 | 04:57 PM
trbokmro's Avatar
Default 2002 Avalanche Electric Fan Conversion Not working HELP!
I have ran into a strange issue which on paper should work, I installed a dual fan setup from a 2006 silverado which fits like stock. I did run a new ecm pin to pin 42, wired a new relay and do not get any signal out of the ecm.
Has anyone figured out what needs to be done to get the signal from the ecm or if it even is possible for the 2002? I have H.P. Tuners and tried turning it on at 160, tried both fan options still with no luck.
Any help would be great!
Thanks
Old Oct 28, 2011 | 01:53 PM
trbokmro's Avatar
bump, anyone?
Old Oct 29, 2011 | 01:41 PM
budhayes3's Avatar
PT's Slowest Truck
Be sure that the PCM pin is fully seated in the connector, it can be tricky...
Old Oct 30, 2011 | 04:49 PM
trbokmro's Avatar
does your fan setup connect to the ecu pin 42 also? thanks for the help!
Old Oct 30, 2011 | 05:09 PM
trbokmro's Avatar
have the fix, found out the pcm does not send a positive signal, simple relay rewire and should be good to go.
Old Oct 30, 2011 | 05:12 PM
Atomic's Avatar
I have a gauge for that
yep, fans turn on with a ground, not +
5.3Okasai
Mar 9, 2022 01:07 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ketis
Jul 23, 2015 12:37 PM
01sierraon22s
Jul 8, 2015 11:26 AM
