2 bar base VE needed
Old May 29, 2011 | 01:35 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
http://www.hptuners.com/forum/showthread.php?t=14425
http://www.hptuners.com/forum/showthread.php?t=5058
Check as many of those out as you have time for. Poke around on the HPT board, spend some time searching, there's alot over there. Check out the FAQ threads also.
Old May 29, 2011 | 02:43 AM
stock48's Avatar
9 Second Truck Club
Thanks man I really appreciate the help!
Old May 29, 2011 | 03:22 AM
Bring your truck up here, and I'll do my best to help you dial it in! Haha!
Old May 29, 2011 | 04:27 AM
stock48's Avatar
9 Second Truck Club
Who knows could happen, I've been wanting to check that place out
Old Jun 1, 2011 | 02:16 AM
TURBHOE's Avatar
make sure that you set up the PE tables. i set mine to come in at like 30% throttle because i can make boost down that low. but i have the lower rpm portion lean because it doesn't need as much fuel at that low of boost/rpm.
Old Jun 1, 2011 | 02:34 AM
stock48's Avatar
9 Second Truck Club
Been working on it, and running pretty good. Kept the 1 bar and built a new VE for the E85. The sd didn't feel as crisp. Soon as I get back to califukhole I cant get E85 or good enough fuel to need 2bar any way.
Old Jun 18, 2011 | 03:30 PM
89LS1FOXER's Avatar
Mine is on a 2bar sd tune with 4l80e too, felt way better than the 1 bar maf, feel free to use it if you need to.
Old Jun 22, 2011 | 06:13 PM
TURBHOE's Avatar
Yeah the 2bar takes some work but once it's in it's nice. So far i have noticed that from 105-210 it takes basically the same numbers all the way down. I need to do a little bit of work to mine I think it needs a touch more timing on take off. It's been so long since I've even touched it that I have to down load my tune off my truck to be sure I use the right tune. Lmao.
Old Nov 1, 2011 | 07:31 PM
Charlie@LsXperts's Avatar
Having trouble getting my 07 to go 2bar
Old Nov 1, 2011 | 07:37 PM
Atomic's Avatar
I have a gauge for that
that the 99-07 style or the newer 07+ style?
