1,4,6,7 Coils Not Firing-Troubleshoot?
Old Jan 9, 2008 | 09:08 AM
  #21
Do you have EFILive? If so you can activate the PID for "Time Between Crank Reference Pulses", "Crank Angle Sensor Error", "Cam Signal Input High To Low" and "Cam Signal Input Low To High" and view the signals on the Data page. compare that to a stock truck and that should verify the inputs of both sensors. as far as the clocking of the reluctor i would imagine it would still fire all eight.
Old Jan 12, 2008 | 01:51 AM
  #22
sliderbkt's Avatar
Well, we went straight to the motor. I bought a 5.3l that was swapped because it smoked and made noise. They thought it was a broken piston. Anyway, I just needed something to swap in to see if the coils fired. I threw it in today and it fired right up. So, the problem seems to be with the new motor. It does have the 28x reluctor.
I'll email the builder and see how they handle the situation.
Old Jan 12, 2008 | 02:11 AM
  #23
Wilde Racing's Avatar
How do I change this text
Damn that sounds like a lot of work, sorry to hear that. but at least you found the problem,err getting closer...
Old Jan 12, 2008 | 02:16 AM
  #24
sliderbkt's Avatar
Yeah, I'm still not sure if I'm happy or upset. I guess I'll see how the builder handles it, then decide. But at least I'm not chasing a ghost.
Old Jan 15, 2008 | 08:23 PM
  #25
sliderbkt's Avatar
Looks like ther reluctor was/is the problem. I measured the runout today and it is .013 which is more than it should be. It should be less than .01. The cranks endplay is .006 just pulling it by hand, so it may be above tolerance too.
REDCYCLE13
Sep 15, 2016 03:02 PM
00loudchevy
Dec 3, 2015 05:54 PM
OHsixLS3
Nov 21, 2015 10:41 AM
The_W
Oct 1, 2015 02:35 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
