07-08 MAF and 10+ MAF pinouts needed please!
If you get a replacement pigtail the pin id isnt always stamped on the connecyor, the same connector body is used for a few different things throughout the vehicle, maybe i dont get it either, but when i have to wire **** in from one connector style to another, i want both wiring diagrms both connector end views and will check, double check, recheck and before i plug anything in i will check it all again against the diagrams just to be sure its done right... and i dont care if its a 3 pin map sensor connector, or a 42 pin engine harness connector, better to be safe than sorry, less expensive to print off a couple extra sheets of paper to make sure you are only doing it once than to connect one wore to the wrong pin and fry something, becuase its a 12v signal where a 5v should be, or a 12v input into a ground... either would be bad and let the smoke out of something.....then you have to send it off to het the smoke put back in...
