06 motor in 01 help
Old Apr 12, 2020 | 10:19 AM
dansmith's Avatar
Registered User
Default 06 motor in 01 help
Can anyone help me on wiring
Put a 06 6 liter and 4l80 in my 01 that had 4.3 4l60 in it
took all engine wiring harness and computer from 06 but now i need to know how to wire it to the factory 01 fuse box and underneath plugs
wanting to make it as stock as possible
Also what would it take to put the cruise out of the 06 into the 01
Old Apr 13, 2020 | 05:42 AM
RedXray's Avatar
100% Redneck
You need a 99-02 V8 harness. The 99-02 harnesses are different than the 03+ V8 harness. It will be easier to use a cable throttle body and return fuel rails with the fuel pressure regulator. Does the truck have two fuel lines one supply and a return? You'll need to modify the trans connector if the 99-02 harness comes out of a 4L80e truck.
blazinblue
Sep 21, 2009 12:25 AM
04BlackSilverado
Apr 10, 2006 03:25 PM
