03+ cluster in 99-02
Old Jul 19, 2012 | 09:09 AM
cammed00's Avatar
I'd wanna do the swap when I get time and your available
Old Jul 19, 2012 | 09:55 AM
mvrk10256's Avatar
Avalanche can you PM me the details involved in doing this swap?
Old Jul 19, 2012 | 05:55 PM
way2much_01's Avatar
^^^^ me too... will 03+ steering wheels work in 99-02?
Old Jul 19, 2012 | 06:18 PM
TXSZ66AVLANCHE's Avatar
Steering wheel will work, with lots and lots and lots of work.....lots of work.
Old Jul 24, 2012 | 04:18 PM
LiLez02's Avatar
i would loan my truck in a second if i was close. whats involved in the steering wheel? whole column? i tried it once and it was close but i just couldt get it on so i sold the wheel
Old Jul 27, 2012 | 01:43 AM
It'll work but if I tell ya the trick I'd have to kill ya. It involves alldata and a complete bcm retrofit and changing the doors over to newer style driver door and passenger door module control via the bcm to do it right.
If you wanna rig it you can leave the old bcm as a slave to control the door locks only. It's a major PITA and not for the faint of heart or those with weak wiring skills.
Did it on my dads 02 for him. If I had it to do all over again it would be way easier to just grab a complete inside outside harness from a newer truck then it's plug and play.
Old Aug 10, 2012 | 12:10 AM
400ss's Avatar
why you need to do that? i think you only need to swap some wires location on the ipc connetor te only gage that will now work its the oil pressure, 06 uses the serial data to run it, 01 uses bulb signal directly to the ipc, you can get a 01 bulb and wire it to make it work
Old Sep 17, 2012 | 03:12 PM
99silversled's Avatar
wondering about this swap i have a 99 and just bought a 04 ss cab complete thinking about doing this swap any help ????
Old Sep 19, 2012 | 12:16 AM
Suburbazine's Avatar
It won't work because while you can wire up all the correct wires and make everything go to where it should, the cluster computer will shut the whole cluster down for a programming error the moment you attempt to power it up.
Old Sep 19, 2012 | 12:24 AM
chevrolade's Avatar
Tried putting a 03' cluster in a 02' once and blew fuses lol
