The truck has 105,000 miles with only about 16,000 on the built motor. This combo should be good for about 750 crank HP the way it sits. It has every option available in a 2009 including AC seats, a heated steering wheel and a sunroof.
Truck will be sold on BMF Novakane wheels which I will have pictures of shortly.
Clean title, in hand.
Performance parts:
416ci stroked LS3 at 9.5:1 compression. Callies Compstar crank and rods with Wiseco pistons. Spec's found here: https://golenengineservice.com/wp-co...ted-SB-Web.pdf
Melling oil pump
NEW lifters and hardware went into this motor when it was replaced
2.3 whipple making 10psi with a 3.0" blower pulley.
OD 8 rib Balancer
1 7/8" ARH catted exhaust system with a borla cat back.
230/246 cam on a 117lsa. .620 intake lift and .604 exhaust lift.
Ported LS2 throttle body.
Circle d triple disc converter.
83# injectors with a factory e85 fuel pump.
Interior is extremely clean with the following stereo modifications:
Alpine 9" navigation with Boston acoustic speakers in all 4 doors and 2 12" subs. Capacitors to make sure the electronic system can keep up. About 7500 invested in the audio system alone.
There are a ton of other mods that are not listed like sway bars, tri folding fiberglass bed cover, etc... if you can think of it this truck has it, and I have receipts to back it up. Direct message with any questions.
$27,995
