1996 RCSB s10 LSX swapped roller
Old Aug 14, 2015 | 07:42 AM
ss454327's Avatar
Default 1996 RCSB s10 LSX swapped roller
The truck is together and running right now but I'm going to pull the engine/trans and go another route.
Asking $2000 for the complete roller
1996 rcsb s10, notched/boxed frame for AC, relocated Fbody fuel tank (was 4.3/NV3500)
Ford Explorer 8.8, 3.73 gears and disk brakes (drilled for GM bolt pattern)
BRP 1 3/4" in frame LT headers, coated
BRP transmission mount
CPW plug and play swap harness
CPW poly engine mounts
Jegs aluminum radiator
Dodge Interpid dual fans
Aluminum remote PS reservoir
Homemade Cal-Trak bars
Racetronix fuel pump with hotwire kit
16" Camaro wheels with brand new Falken tires
Had a fiberglass roll pan that I never installed
It has a small dent in the driver side fender by the headlight
One of the wheel studs on the passenger side broke loose while I was changing wheels/tires
It needs a new windshield
Need to figure out where you want the fuel fill
The drain plug on the radiator stripped (easily fixable)
Old Aug 14, 2015 | 11:24 PM
Stroik05's Avatar
more pics!
Old Aug 19, 2015 | 12:13 PM
ss454327's Avatar
Sure thing...just some more info this truck got a cab off swap. I painted the frame with Rust Tough Enamel in semi-flat black. The 8.8 has a Perfect Launch diff cover too.
Old Aug 29, 2015 | 02:37 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
were are you located
Old Aug 31, 2015 | 09:18 AM
ss454327's Avatar
Scott Arkansas
Old Oct 17, 2015 | 10:14 AM
Sbailes007's Avatar
I'm in Rogers, AR and have been looking for an LS swapped g2 s10. Would you sell the truck complete?
Old Oct 17, 2015 | 03:43 PM
05chevy04yfz's Avatar
Originally Posted by ss454327
Scott Arkansas
So pretty much drop a engine and tranny and go for the most part?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
Jake99
Aug 8, 2015 07:56 AM
Go5.3tt06
Jul 20, 2015 08:00 PM
4B11T
Jul 13, 2015 03:48 PM
