02 GMC LS1 w/ Turbo
O2 GMC Sierra " SOLD "
2002 GMC Sierra scsb 81K miles
Engine Specs, around 10k miles on motor
HKE Preped LS1 block 3.905 bore 9.4-1 CR
Mahle forged -16cc Dished pistons
Compstar Rods
Stock LS1 crank
ARP head studs and bottom end studs.
Comp Cam 226/222 568/558 115LSA
Ported 706 heads with Gold dual springs
Double Roller Timing Chain
LS6 oil pump shimmed for more oil pressure
LS2 MLS head gaskets
Transmission around 8K miles on tranny
4L80E fully built by Transformance
Deep cast alum pan
Art Carr Billet converter 2800 stall
3.5" driveshaft with 1350 slipyoke
Remote mount turbo kit 2K miles on turbo kit
Stock Cast manifolds
Mandrel bent Y pipe Ceramic coated Silver
Turbonetics TC78 with a .96A/R
38mm wastegate 7 psi spring
50mm BOV
Boost controller set at 12 psi.
Alum. Front mount intercooler
3" exhaust ,Thrush 2 chamber dumped before the rearend
Fuel System
Dual intake walbros
Billet fuel rails with FPR
60lb injectors
Guages
White Face innovative wideband
White Face Autometer Boost gauge
Autometer Dual pillar pod
Camaro Electric Fans
Drilled and slotted rotors
[/URL]
[/URL]
Compstar Rods
Stock LS1 crank
Deep cast alum pan
50mm BOV
Fuel System
Dual intake walbros
60lb injectors
Guages
[/URL]
[/URL]
