Wolftrk99 and 1FastBrick can't stop BSing thread...
Old 11-17-2015, 10:35 PM
  #141
Custm2500's Rude Friend
1FastBrick's Avatar
That one I am not sure.
Most truck cams are relatively small. Less than .200 duration less than .480 lift around 114-116 LSA
Old 11-17-2015, 11:04 PM
  #142
Wolftrk99's Avatar
Wonder how the cam i have in my 99 would act in the 5.3 in my 08....
Old 11-17-2015, 11:41 PM
  #143
1FastBrick's Avatar
From what I could find, there right at .480 lift but no one could confirm duration or LSA.
If I had access to one I could have it checked on a Cam Doctor. Supposedly this is the Oem part number for the cam you mentioned. 12625436
I did find this cool article though that I thought I would share...
http://www.enginebuildermag.com/wp-c...0000054947.pdf
As for your last question, You would probably loose a little power.
You could have it re-ground though to get a little more out of it...
Old 11-18-2015, 09:11 AM
  #144
Wolftrk99's Avatar
How would i lose power???
Old 11-18-2015, 12:02 PM
  #145
1FastBrick's Avatar
Because I said so...
I am just guessing that the fact that the HP rating is higher on the newer vehicles that you might lose power. Not to mention the 99 was the smallest of the cams. Of course they went to a flat top piston so who knows... As you can see with the specs I have found, they are fairly similar between the years. I can't imagine the DOD or AFM cams are much different.
4.8/5.3L LM7 LR4 L59
99 12560966 191/190 .457/.466 115.5
00-06 12560967 191/190 .457/.466 114
L33 5.3L
05-07 193/193 .479/.479 116
LQ4
99-00 12560967 191/190 .457/.466 114
01-06 12561721 196/207 .467/.479 116
LQ9
02-06 12561721 196/207 .467/.479 116
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration 0.496" / 0.496" int/exh lift 116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration 0.467" / 0.479" int/exh lift 116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration 0.525" / 0.525" int/exh lift 116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration 0.551" / 0.547" int/exh lift 117 LSA
LS2
204/211 0.525/0.525 int/exh 116 LSA
Look at this article. Kind of a neat comparison on factory cams.
Look at the bottom of the article where the LSA cam is compared to the LM7. I wouldn't be surprised if that cam was the same as the AFM cam.
LS Cam Test Comparison - Car Craft Magazine
Old 11-18-2015, 12:23 PM
  #146
Wolftrk99's Avatar
Im talking about the cam in my sig.... My lm7 cam was toast!!!!
Old 11-18-2015, 12:41 PM
  #147
1FastBrick's Avatar
Oh, Not sure in an SUV with the extra weight, but it shouldn't be much different from your truck.
Old 11-18-2015, 01:58 PM
  #148
Wolftrk99's Avatar
So no *** off line and shitty fuel mileage around town.... Got it lol
RaceReadyPerformance
01-06-2016 09:13 PM
mhotrodscooter
12-21-2015 02:39 AM
Dug1234
11-14-2015 11:50 AM
Jaxon2580
38
11-06-2015 01:39 AM
dajuggernoff85
10-31-2015 07:36 PM
Quick Reply: Wolftrk99 and 1FastBrick can't stop BSing thread...
