Step by Step build of 28,000HP Diesel
Old Oct 3, 2007 | 05:14 PM
KySilverado's Avatar
Great pictures. I'm amazed at how simple it is... just large.
Old Oct 3, 2007 | 05:22 PM
Spoolin's Avatar
GFYS and STFU
Glad you guys like the pictures. Biggest engine I've worked on was rated at 79,000 HP and everything was bigger proportionally. These pistons were more or less 2 feet wide while pistons on the bigger engines range between 3.5 - 4 feet in diameter. Should be noted that these pistons produce their power due to Stroke length and not Bore size. Torque on these engines are over a million.
Old Oct 3, 2007 | 06:00 PM
ZZebes's Avatar
http://people.bath.ac.uk/ccsshb/12cyl/
Info about the 5,000,000lb/ft version with a 96" Stroke
Old Oct 3, 2007 | 07:01 PM
dirt track racer 81's Avatar
Originally Posted by Richard@WCCH
Nothing like having a walk in door to your crankcase!
i made a hole in the side of my crankcase to stick both my hands in there..
Old Oct 3, 2007 | 07:16 PM
truckmann's Avatar
Did you try stickin your hands in there while it was running??
Old Oct 5, 2007 | 07:55 AM
OnyxSilveradoSS's Avatar
nice pics. that crank is a thing of beauity, I would make one into a tree house/hunting stand
Old Oct 5, 2007 | 02:15 PM
Spoolin's Avatar
GFYS and STFU
Lol, that would be pretty funny but not a bad idea, multi layered so your buddies can be on top or bottom and have a better line of sight...might work.
Old Oct 5, 2007 | 02:27 PM
jblack6527's Avatar
That's pretty sweet, thanks for sharing man!
kbracing96's Avatar
28,000hp power and only 115 rpm with that low of RPM, I can't even imagine the torque numbers
I wonder how many gallons of diesel are injected per stroke?
Old Oct 5, 2007 | 02:51 PM
Spoolin's Avatar
GFYS and STFU
They run on Diesel when we are in port or coastal waters as it's the cleaner burning fuel and run on HFO (Heavy Fuel Oil) or Bunker C when out at sea. The last two fuels are the last of the last refining process when refineries separate out all the different fuels. Actually the last one is Asphalt. Anyways HFO and Bunker C is some Heavy *** ****. When it's cold you can actually walk on it, it's consistency is similar to cold tar. They have to heat it up to 120-140 degrees Celsius to get it hot enough and viscous enough to pump it around and into the engine.
Not sure if you guys remember a ship that ran aground in Oregan that the Navy tried to blow up? They set off mulitple types of explosives in an attempt to destroy it or light the fuel on fire but they failed until finally they used Napalm to ignite the fuel. The thing burned for a few days. Burning Cold HFO or Bunker C is similar to attempting to make a candle explode.
