Quick Need Help on 220v wiring
Old Sep 6, 2008 | 04:04 PM
dirt track racer 81's Avatar
Default Quick Need Help on 220v wiring
Gotta new welder and im no electrician. the welder I got has a different plug in. So I bought the female plug in for it and was just going to put that on my extension cord that way I dont have to redo everything. I know which wire is the ground but the other 2 HOT wires, do they have a specific side they go to?
Old Sep 6, 2008 | 04:16 PM
Wilde Racing's Avatar
How do I change this text
http://www.lowes.com/lowes/lkn?actio...220outlet.html
Old Sep 6, 2008 | 04:21 PM
i just have 3 wires.. not 4. does it matter were the white neutral wire and hot wire goes. it doesnt show which wires to hook up for 3 wires. also i dont know what lugs are what
Old Sep 6, 2008 | 04:24 PM
i gotta black, white, and green wire..isnt the green ground?
Old Sep 6, 2008 | 04:29 PM
viciousknid's Avatar
Where's the Beef?
I don't think you should run a 220 on a 110 cord you dangerous bastard. Didn't you learn anything about safety when you got metal in your eye? Go buy a 220 cord
Old Sep 6, 2008 | 05:05 PM
xchevyx24's Avatar
if you run 220v through a 110 cord or evan outlet you will be blowing the breaker about every 30 seconds and yes green is ground
Black = Hot
White = Neutral
Green = Ground
Old Sep 6, 2008 | 05:14 PM
Where's the Beef?
How many amps is your welder going to require?
remember that 110v x 15amp cord = 1650 assuming your cord is rated at 15amps. Your welder is going to have to pull less than 7.5amps to keep the cord from burning up. 1650/220=7.5a
Old Sep 6, 2008 | 05:21 PM
its already 220..these are just the wires i have
Old Sep 6, 2008 | 06:27 PM
Stoichiometric's Avatar
10 ga for 30amps. For 2 phase 220 the hots don't matter which position they go in. The neutral should be in the middle. Sounds like you don't have a ground.
Old Sep 6, 2008 | 06:35 PM
You need a 3 conductor cord with a ground.
