Kaboooommmmm
Old Mar 17, 2011 | 06:57 AM
  #121
Bumpers's Avatar
looking good.. I hope you cut those pistons in the right places
Old Mar 17, 2011 | 07:37 AM
  #122
00buckshot's Avatar
Good to see some progress Stew!
Old Mar 17, 2011 | 08:51 AM
  #123
TXsilverado's Avatar
Damn thats an old *** drill
The pictures are of him flycutting the pistons.
just proves that they dont make them like they used to. the only bad thing about this drill is if you use it for long periods of time it gets hot as a mother! but that only happened to me when i was polishing the wheels with it. it will twist your arm off! old craftsman
Old Mar 17, 2011 | 08:58 AM
  #124
Originally Posted by 06Sierra2
dang, im at work and i cant see the pics! i got the little boxes with red x's in them! i been following this thread since the beginning. whats going on? updates...
i got 1 side of the valve reliefs done last night. its gut wrenching on the first cut, but after 2 or 3 cuts it's not too bad. just tedious trying to keep it clean and having to pull the heads 4 times to get the job done. while moving the cut valves over each time. this is what the cutter looks like. sliced these pistons like butter.
waiting on an oil pan gasket, manifold gaskets, 2 ls7 lifters and the motor will be done. hoping to pull the engine this weekend, get the converter re stalled next week and have it in next weekend.
Old Mar 17, 2011 | 08:33 PM
  #125
Jake99's Avatar
Nice, whats the converter getting stalled too?
Old Mar 17, 2011 | 09:00 PM
  #126
2004SSS's Avatar
nice man , good to see you making progress.
Old Mar 17, 2011 | 10:59 PM
  #127
Bumpers's Avatar
How do you know how deep to go making the valve reliefs?
Old Mar 19, 2011 | 02:47 AM
  #128
gtosilverado's Avatar
well since he said he had to take off/put on the the heads 4 times, i assume you cut and test, cut and test, cut and test.... but also he had a measuring tool on one of the pics. just my guess from the info i see
Old Mar 19, 2011 | 07:43 AM
  #129
sprayedenali's Avatar
he had to take the heads off 4 times to move the cutters to the next cylinder.
im sure you just measure the valve lift and then add your desired tolerance and thats about it...
Old Mar 19, 2011 | 09:35 AM
  #130
theres a stop collar that you slip over each valve stem. you slip in the feeler guage combo that measures to the thickness that you want to cut and lock that stop clooar down with an allen wrench. (stuff the feeler guage between the top of the valve guide and the stop collar.
this is done while the cutter is sitting on top of the piston while at TDC. that's how you get the exact cut on every piston
