Header install pics from last weekend
Old Feb 3, 2010 | 08:42 PM
Black'Rado's Avatar
how hard was it to install them? did u go from the underside? anything special to get em in there?
Old Feb 3, 2010 | 08:52 PM
SLOXCAB's Avatar
i just had my truck up on 4 ramps and went from the underside. its was pretty easy expect for the stock y pipe to manifold bolts gave me some grief
Old Feb 3, 2010 | 09:26 PM
Black'Rado's Avatar
ok cool...ill probly end up cutting my ypipe up....im also going to get the studs and stock gaskets and some bandclams
Old Feb 3, 2010 | 10:09 PM
SLOXCAB's Avatar
ya cut it up just hit the bolts with some pen lube a few days before
Old Feb 3, 2010 | 10:16 PM
Black'Rado's Avatar
ha yea i allready started to spray the manifold bolts with pb blaster! i just really hope none break
Old Feb 3, 2010 | 10:18 PM
GMCtrk's Avatar
I wouldn't cut up your stock Y. You never know when you'll need it again and they're expensive to buy because of the stock cats!
If you can't get it off I would just grind off the offending bolt.
SLOXCAB's Avatar
hit the bolts that connect the manifolds to the y pipe
Old Feb 4, 2010 | 08:44 AM
SILVERADO11's Avatar
looking good man!
Old Feb 4, 2010 | 11:05 AM
D_reks{5.3}'s Avatar
I sprayed mine with PB blaster everyday for a week before i did my headers and they still didnt budge ended up having to hack the Y up.. Hope you have better luck
Old Feb 4, 2010 | 12:39 PM
AJII's Avatar
All of the NNBS trucks use the 90 degree plug wires. Search ebay. Only like $20.
