Garage wiring help
Old Feb 6, 2010 | 09:53 PM
TurboGibbs's Avatar
Default Garage wiring help
Wiring my new shop and can't remember how many outlets you can have on one circuit, 6 or 7? Anyhow, I have 20 amp breakers and 20 amp recepticles and using 12 ga wire. Any help would be appreciated.
Old Feb 6, 2010 | 09:59 PM
JoeGibbSilverado's Avatar
dont know if it helps, but i did a quick search
.The U.S. National Electrical Code Article 220.3 (B) (9) has guidelines for calculatiing general 120 volt dwelling-unit receptacle circuits as having a load of 180 volt-amps per receptacle.
Because a normal circuit breaker can only be loaded to 80 percent of trip rating, then 0.80 X 15 = 12 Amps. 12 Amps X 120 volts = 1440 Volt-Amps per 15-Amp circuit. 1440 VA / 180 VA per receptacle = 8 duplex receptacles per circuit allowed.
For a 20-Amp circuit, you are allowed (.8 x 20 X 120)/ 180 = up to 10 duplex receptacles per circuit.
Old Feb 6, 2010 | 10:04 PM
TurboGibbs's Avatar
Cool. I've been searching but haven't found that much detail. Thanks.
Old Feb 6, 2010 | 10:08 PM
no prob
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
