EDC Flashlights
Old Dec 3, 2011 | 12:33 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by dlt76028
i give up
Thanks for the input David
Old Dec 3, 2011 | 12:35 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
A couple years ago I swapped out for an LED bulb. Made a big difference in battery life, but the LED bulb makes the beam more accute instead of a flood pattern.
Old Dec 3, 2011 | 12:39 PM
Wearin' da big hat
I know what you mean about that, but that is a problem with the LED conversion. The newer versions of the full on LED Maglite flashlights are much better. They're also a lot brighter than the conversion because of nicer LEDs being used and they dissipate heat much better.
Sorry if I sound like a flashlight geek all the sudden, been reading all morning about flashlights before I spent $80 on one.
Old Dec 3, 2011 | 12:41 PM
smokeshow's Avatar
Mod with training wheels
Scott...we already knew you were a flashlight geek. Don't be ashamed.
Old Dec 3, 2011 | 12:46 PM
Wearin' da big hat
I have quite a few flashlights, most of them are cheap ones that I've been given on holidays and stuff. I have two Maglites (first one was given to me by my Uncle a longgggggg time ago) that I've always liked, and I use a flashlight at work all the time so I figured it'd be a good time to get something nice. It'll have more output than my LED Maglite, but a fraction of the size and weight, and I can use a rechargeable battery in it. Ya it's $70-80 but who cares, at least it's something I'll use. I've spent way more money on things I rarely use (AR15, AK74, etc) but it's nice having things you want, and I won't have to worry about buying them in the future when I may not have as much extra cash.
Old Dec 3, 2011 | 12:53 PM
1slow01Z71's Avatar
Id like to get a rechargeable one to mount in my truck but Ill admit Im too lazy to do the proper research on what to get. Id like to get one about half the size of my maglite so it wont take up so much space under the dash of my truck.
Old Dec 3, 2011 | 12:58 PM
Wearin' da big hat
What's your budget? FYI the light I bought puts out 304 lumens vs your converted maglites 80-110 lumens. It probably won't have the throw (distance capabilities) of the maglite due the smaller reflector and total size, but it has very good flooding will be PLENTY bright. It uses an 18650 rechargable battery which is also Lithium Ion, so that means you can top it off whenever you want without messing with it's charging capabilities like the old NiCad batteries. I should have it Monday, but may not be able to use it until Tuesday after I give it a good charge. If you're interested I'll let you know how it works out.
Old Dec 3, 2011 | 01:03 PM
Wearin' da big hat
Check this out. This is a video showing the one I bought vs one of the actual 3D LED Maglites (~140 lumens, brighter than your converted one). It's hard to tell the difference between modes as the camera adjusts, but when he brings the maglite back out at around a minute in, the difference is crazy.
EDIT: Actually that's a PD30 which is an older model. The PD31 would be even brighter.
Fenix PD30 R4 vs Maglite 3D Cell LED.AVI - YouTube
Old Dec 3, 2011 | 01:10 PM
1slow01Z71's Avatar
Less than 200
Old Dec 3, 2011 | 01:26 PM
Wearin' da big hat
Less than 200
That should be really easy to do then
