I may have under tightened it since I couldn't find what torque setting to use and I have a tenancy to over tighten things unless I can find the torque setting
I forget the Torque spec off the top of my head but it is in inch pounds. Even at that, 1/2 the time, at least 1 side pulls the thread. When this happens, I install a product called a keensert on both sides. They are much stronger and retain the bolt better than the raw aluminum threads. I have yet to have a leak after that.
I bought GM Genuine replacement cooler lines for my 06 LQ4, since the old ones had started to seep. I have not installed it yet. I "think" it came with the crush metal type gasket. 🤔 I'm kinda worried now about installing it, LoL
I installed the FelPro block off plate with has the rubber O-ring like the one you posted on my 99 Silverado and I don't believe it has leaked.
Yeah, I guess I need to buy a manual that has torque settings so I can actually torque this to factory specs
When I was a young guy turning wrenches... when they said "tighten it down real good"... I experienced a few times where I tightened things down so hard the bolts either stripped or broke, and then they would tell me "you caused it, you fix it" and then I was drilling and putting in heli coils which as you know is really hard in areas with little room to work
So, I always remember now to not tighten things too tight
