Definition of Acceleration
Old Jan 9, 2009 | 08:03 AM
BLK WDO's Avatar
Default Definition of Acceleration
Sorry it this is a re-post. i love it, thought i'd remind people and let new people read it!
For all you NHRA fans out there A Definition of Acceleration
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of NASCARS at the Daytona 500.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture for nitromethane, the flame front temperature measures 7,050 degrees F.
Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 degrees F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top Fuel engines turn approximately 540 revolutions from light to light!
Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second.
The current Top Fuel dragster elapsed time record is 4.428 seconds for the quarter mile (06, Tony Schumacher). The top speed record is 336.15 mph. (533 km/h) as measured over the last 66' of the run (05).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
Old Jan 9, 2009 | 08:11 AM
95 bright teal's Avatar
Ive seen some info before, but that was alot of good stuff, nice post!
craziness
Old Jan 9, 2009 | 08:15 AM
454navyss's Avatar
i've seen that before but its cool to read it again
the records were broken though, tony schumacher went 4.428 in 06 and 336.15mph in 05 according to:
http://www.nhra.com/stats/natrecord.html
Old Jan 9, 2009 | 08:30 AM
BLK WDO's Avatar
edit made lol. i read that like 5 6 years ago, love it. shows how much sheer power a engine can make!
Old Jan 10, 2009 | 11:11 AM
XLR8NSS's Avatar
Adkoonerstrator
That last part always gives me goose bumps when I read it.
Old Jan 10, 2009 | 12:26 PM
jaegmc99's Avatar
incredibly awesome
Old Jan 12, 2009 | 03:07 AM
silver-mod-o's Avatar
Hunt&Fisherator
If I remember reading this correctly a while ago, they reach 100mph from a standing start in less than one second!
Old Jan 12, 2009 | 04:08 AM
BlackLM7's Avatar
Yes, I've heard about that too.
All those facts sound impressive but you don't get the sensation of speed and power unless you see a NHRA event in person. It's really is a life-altering event, especially if you're next to the starting line.
Old Jan 12, 2009 | 04:30 AM
LowBlack99's Avatar
Ive been to many NHRA events, NASCAR too. They are both a blast. I got sit in the starting line boxes for the NHRA a few years back, what a rush!!! We could also go up on the tower and man when the nitro blast hits you, you will cry like a little girl!!
Old Jan 12, 2009 | 07:18 AM
BLK WDO's Avatar
i hear ya! but put into perspective of a Vett goin by at 200 and still pushing it just to get BLOWN off the track makes you think......DAM!
