D-Max powered GNX?!?
#21
here's my best attempt at explaining,
a diesel turns a max of 3250rpms from the factory, and im not up on their tuning but i dont think they will turn over 3500-4000rpms(without heavy mods). a gas engine of the same size 6.6L(402cu.in.) could turn 6500-7000 + without heavy mods. less rpms means less friction ( from what i understand) which means less heat.
with Whippled_496's thread, he has the 8.1L (496 cu.in.) gas engine which turns about 5000rpms. he wanted a large intercooler as his whipple was without one at the time, so he looked at the factory DMAX setup and found that in order to use the DMAX intercooler, he had to use the DMAX radiator and after he installed it and started doing logs and watching his gauges he found that the DMAX radiator was incapable of keeping his engine coolant temps down to an acceptable level, therefore he had to put his stock radiator(from the big block) back in and get the whipple intercooler for the 8.1L.
the part i dont understand about it is the diesel guys have to watch their EGTs when towing or using a tuning program/box, but i believe that is from the excess of unburnt fuel
what i am trying to say is a diesel engine produces less engine heat than a gasoline engine does and therefore doesnt require such an effective cooling system(as in a large radiator, etc.).
EDIT: this thread probably has the most info but he has a few more threads about his "I/C sagas"
https://www.performancetrucks.net/fo...or+intercooler
#24
Originally Posted by TBSS
It's a Cutlass with a GN rear clip. The guy who built it is a smart cookie; he got the Cutlass because it started life as a diesel, and as a result, the VIN is not subject to the normal CA smog checks. So his conversion is perfectly legal, in spite of the fact that it will likely have in excess of 500HP/1000TQ. Very elegant. I bet it will turn over those meats as well.
Too bad they didn't make a rcsb diesel for the GMT800
#26
Originally Posted by Scream
Sweeeeeeeet! I think it's a GN w/ GNX badges though...don't see the hood vents.
at 50-70K a pop, i doubt its a REAL GNX.......pretty cool none the less.
#27
Only a moron would do that to a real GNX. It's a converted cutlass. He started with a diesel car so he wouldn't have to **** with smog / emissions testing. It's a good idea to start with a diesel Cutlass so you don't have to worry about emission testing...in parts of the world where they do that, like here in MD.
#29
