Bombardier Outlander 400 Help
Old Nov 16, 2009 | 03:15 PM
texasbullseye89's Avatar
Default Bombardier Outlander 400 Help
I've got a 2003 model that the shift lever goes into gear, but it wont move. took the cover off and have no idea what the problem is cause its that damn CVT transmission anyone know anything about them?
Old Nov 16, 2009 | 06:14 PM
smasho275's Avatar
You try just moving the quad by hand back and forth, maybe to get the tranny back into gear?
Dgrown's Avatar
check the condition of the belt cause if you get them wet then they slip and wont move
Old Nov 16, 2009 | 07:44 PM
tried rockin it. didnt work. belt is fine. well, it looks fine, how loose is it supposed to be? about like a serpentine belt?
Old Nov 16, 2009 | 11:35 PM
Dgrown's Avatar
it funtions the same as a sled trans... if you have those down there umm it should be a bit tight and as you rev it up the belt should get tighter and if thats not happening then its a clutch issue... hence the reason why i love my standard racer less issues
Old Nov 17, 2009 | 01:12 AM
marlboroman71818's Avatar
the clutches engage on the sides of the belt and squeze down and tighten the belt some. what where you doing when it started this. you probably have a burnt spot on the belt and when that happens the worn out part of the belt stops directly on the clutches. leave the clutch cover off and see what it does when you prop the rear up and give it some gas.
Old Nov 17, 2009 | 07:30 PM
yeah no sleds down here. the cover is off. when you start it in neutral the engine side pulley moves and pulls the belt along, and it grabs the trans pulley too, pop it in gear, and the trans pulley and belt stop moving.
the engine side is supposed to add the tension right? because it appears that its supposed to move in and out to do that, but it doesnt...
pewter00
11
Oct 20, 2023 05:40 AM
zblee
Nov 11, 2015 12:41 AM
jscherbs
Sep 30, 2015 07:54 AM
1989k1500
Sep 29, 2015 10:53 AM
lt1z350
Sep 28, 2015 12:20 PM
