TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Wrong Transmission Shifter on an '07 TBSS
Old Feb 21, 2007 | 10:45 PM
sstrail's Avatar
Question Wrong Transmission Shifter on an '07 TBSS
Just got my '07 TBSS. I noticed that when I put the transmission shifter in "D" it would take longer than usual to engage into drive. I also noticed that it wouldn't go into 1st when I manually shifted the lever. I took it back to the service department and they looked at it. They said it seems that the factory put an AWD shifter on my two-wheel driver TBSS, and that is what is causing the problem.
TBSS is down for a week pending the arrival and installation of the correct part. Has anyone experienced this problem or heard of it happening?
Old Feb 21, 2007 | 11:07 PM
mwalls54's Avatar
Need More N2O Mod
I wouldn't have thought there would be a difference. I believe they are cable operated.
Old Feb 22, 2007 | 01:16 AM
James B.'s Avatar
The cable is adjustable at the bracket. Sounds like it's off a bit. I cannot understand what difference there could be between AWD and 2WD.
Old Feb 22, 2007 | 02:37 AM
Blown02Sierra's Avatar
IDK why there would be a difference. I would think that they would all be the same to save $$. If it is the wrong one, that's dumb that it got mixed up.
Old Feb 28, 2007 | 11:18 AM
The shifter linkaga needs adjusting. I had to do it on mine. I lost 1st gear because the cable was too tight and did not allow it to go into gear. Did some adjusting and now fixed.
Chad
Old Feb 28, 2007 | 07:36 PM
02RedHawk's Avatar
There is no difference in the shifters on the AWD vs. 2WD. Your dealer unfortunately was throwing you a line....
Old Mar 1, 2007 | 09:09 AM
sstrail's Avatar
Default Problem fixed. Updated information.
Per the service manager the problem had to do with a bushing on the shifter cable. For some reason this bushing was cracked and that affected the way the cable moved when shifted. They changed out the shifter and the cable and everything is normal now.
blownss27
Aug 14, 2020 08:27 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
06 4.8
Sep 11, 2015 10:36 AM
iVorTec
Sep 2, 2015 04:27 PM
