What are my options for using LS1 Fans?
I know PCM for less has a harness out, but do I have any other options?
It's not for me but basically a local guy is gonna trade me an ss3200 in exchange for me installing my set of ls1 efans(which I paid $58 shipped for) +$100 from me.
If I do it right, I'll have a $795 Yank converter for my silverado and it will cost me less than $300.
Thanks,
Mark
EDIT- The reason why I don't just assume use the PCM4less harness is that I'm not entirely sure his tuner will tune for them. So I'm curious as to if there are any good external units available.
Thanks,
Mark
Thanks,
Mark
Thanks,
Mark
There are a ton of different external units available. I only have experience with the FAL external controllers for fans on an old truck. I wouldn't recommend the FAL controllers, they will get the job done but I'm sure there are better options out there. Dakota digital makes a nice one, but it's pricey.
If you find out that his tuner will turn then on in the pcm I think that is the easiest thing to do and DLH2006 is making fan harnesses so you might PM him to find out what he charges for them. I got mine from white1 when he was making them and mine works great and it was very reasonably priced.
I did LS1 fans, 2 relays and a $25 Flex-A-Lite thermostat... Got one fan tapped to the A/C compressor and the other to the t-stat... Never had a problem. Cost me about $35 and a new set of fans for my TA
Originally Posted by Z06 DREAMING
You think white1's harness will work with the TBSS? I have one in the garage from him... and a set of LS1 fans. Any idea on the PCM pin that can be used for fans?
http://www.hptuners.com/forum/showth...ight=tbss+fans
The harness should work fine. I am not 100% sure which pinout you need to use on the PCM, but it looks like pin 36 is the correct one. Here is where I got that from.
