TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
TBSS Lug specs?
Old Oct 2, 2008 | 12:09 PM
dhpro's Avatar
Default TBSS Lug specs?
I need exact specs on 2007 TBSS lugs. Are they conical base or flange? Thread, bolt pattern, and lug dimensions?
Old Oct 2, 2008 | 12:35 PM
InchUp's Avatar
The stud size is 1/2"-20. Conical base. If the SS is no different than the Trailblazer, then the SS is also 6x5" bolt pattern.
On a side note, what does this have to do with off-road performance? Last time I checked the TBSS isn't very well suited for the dirty side of life.
Old Oct 2, 2008 | 01:01 PM
dhpro's Avatar
Sorry! Picked the wrong forum...worked tho! U dirt magnates seem to have the pulse!
Old Oct 12, 2008 | 01:30 PM
1BadAction's Avatar
Registered abuser
way to go, google guru. you wonder how people know you are full of ****
On all trailblazers, the stud size is 12mm x 1.5mm pitch and the bolt pattern is 6 x 127mm. Lugs are conical base. Wheels designed for the 6x5" bolt pattern don't fit correctly, even though 127mm / 5" bolt patterns are supposed to interchange.
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jscherbs
Sep 30, 2015 07:54 AM
okie454ss
Sep 22, 2015 07:39 AM
chvy=power
Sep 8, 2015 11:06 AM
