Paging NorcalTBSS
Hey Tony, when you lowered your *** end, did your TBSS sit lower on the passenger side? I just lowered mine by moving the sensor higher on the frame, and now my passenger side sits about .5" lower than the driver's side.
Go underneath the back and loosen the lines to each air bag enough so they deflate completely. Then retighten them and turn the ignition on and they will raise back up at the same height. If they are still off a little then loosen just that side and bleed a little bit of air. I had to do the same thing when I lowered mine.
Preshr
Sep 6, 2025 09:15 AM
Stainless Works
Oct 8, 2015 12:01 PM
carid
Sep 10, 2015 09:07 AM
